Cabrillo format?
Look at that link, just about all the way to the bottom of the page... "Cabrillo Export Support". I'm pretty sure if you set up this N1MM program and arrange the on-screen format to your own personal preference, it'll export all the QSO information in the correct Cabrillo format as long as you haven't renamed any fields (which shouldn't be possible anyway).
Thanks.
Ok, I downloaded the logger and made it work. Now to learn how to use it...
  • @ Geoexplorer69:
  • @ Geoexplorer69:
