Can anybody help me with an old Turner JM+2U ???
  • Thread starter Thread starter Relic Hunter
  • Start date Start date
R
Relic Hunter
Guest
I have an old Turner JM+2U from when I was a kid. This weekend past I picked up an old "new in box" Midland 77-155 CB at a garage sale and was wondering how the wires are supposed to be set up in the mic connector. Actually, I don't even know if I can use it on there at all 'cause the CB has a "Mic Gain" knob on it. Does that do the same as a powermic? Should I bother installing the mic?
Sorry if the questions seem a little stupid, but I haven't touched a CB since only a few years after they went to 40 channels!
Thanks for any help.
</p>
</p>
Well the wireing for the midland is.
Pin1=Audio
Pin2=Shield or Ground
Pin3=Receive
Pin4=Transmit
Hope this helps
</p>
Pin1=Audio
Pin3=Receive
Pin4=Transmit
Hope this helps
</p>
Thanks Charger.
I really appreciate it. Do you or anybody else here know of any pro's or con's of using it on that CB?
Thanks again.
</p>
Thanks Charger.
Thanks again.
</p>
Thanks Defpom....
....I keep the gain maxed and the mic on 4. Seems to be working well.
</p>
Thanks Defpom....
</p>
midland 77-155
I got one of these rigs from this site.It is sniped does about 10 watts.Had it checked 8/30/11.Works fine needed paint.My tech. is from this site.Any way if you want to sell it or trade it for a TURNER i think it says mod.300. Sliding vol. and tone.It also has the BATTERY TESTER with METTER.Let me know?73s. RAY 713 coathanger N.E. P.A. Email coathanger2@verizon.net.:whistle:;)
midland MODEL 77-155
I got a MIDLAND 77-155 OF A GUY ON THIS SITE.:thumbup:.I use it for a base.Got the dead key around 2. Have a FAT BOY AMP on it does around 180 watts to 200 watts.I think it is a very good rig.Also you can lower the dead key very easy.There is very little mods. You can do with this rig.:thumbup::D:pop:.73s. RAY COATHANGER 713 N.E. P.A. AL MOST FOR GOT I HAVE IT HOOKED TO THE 2000.
  • @ Geoexplorer69:
  • @ Geoexplorer69:
