Can anyone identify this insulating material please?
Well another order and another try.
I re-flowed the mosfets and rectifier leads cause I was struggling and some got moved a bit and looked a bit cracked.
Just got to pull the trigger on some pads and try again in a few days.
Thanks for all of your advice guys.
If they are "pre-adhesive" - go for it - looks like the sizes you need too.
Remember that they are perfed - meaning the hole will need to align - so if they get "inserted" and slide off - the slightest burr on one edge in to the anodized aluminum they may be toast. These are made for drill thrus'.
Reactions: 357
Ya I couldn't find 900 series with no hole for to247
I got the to220 no hole but see for yourself: https://www.digikey.ca/products/en/...402&quantity=&ColumnSort=0&page=1&pageSize=25
I seen the Wakefield-Vette ones but they seem super thin to me.
0.076mm vs 0.229mm
https://www.digikey.ca/product-detail/en/wakefield-vette/CD-02-05-220-N/345-1687-ND/9369966
https://www.digikey.ca/product-detail/en/wakefield-vette/CD-02-05-247-N/345-1688-ND/9369967
https://www.digikey.ca/product-detail/en/wakefield-vette/CD-02-05-REC-125-N/345-1703-ND/9369982
Maybe these are made of the same thing the original ones were.
I'm not sure which one to pick.
I cant believe how much this stuff costs either.
I could probably buy the actual components for less.
Went looking - see above, used the Adhesive back and then hit apply filters - these have adhesive backing so you can get these to work as long as it sticks to the back of the parts.
There will be clearance issues so I can see why they went with typical "onion skin" like you'd find on the transformers...
But Teflon Tape is also a stuff used for electrical insulation too
I also noticed that the heads and nuts - looks like they fit the channel.
Can you use a spot glue or nail polish to hold these parts in place? {the nuts I'm referring to] and place the board on top once the bolts or nuts are properly aligned? I'm thinking the nuts to the channel and just "washers" to press against the top part of the plate to hold the flange to the parts due to the length of the shaft of the bolt - this way the nut when it goes tight - the washer and bolt itself also adds to the spreader effect. The Nut then is your friction "brake" to keep the heat sink aligned.
I'm thinking that if - as part of assembly - one or two nuts of both ends of the board can be done this way - the rest should fall into place pretty easily.
I've used piano - fish wire - to slide the nuts onto heat sink channels in a similar design - PITA - so I know what you're going thru - some have even needed the heat sink "goo" to hold the nut in place and helped quicken the assembly. I'm just providing hints to help you get thru this.
I've had the wonderful job of dealing with backplane cages from some older video games that instead of one board they were caged and had "shared" heat sink assemblies that you had to insert and extract both cards evenly so you didn't torgue off the parts or shift them and wind up with a mess of pieces versus two boards.
The picture on digikey is misleading.
They dont say what rectifier but in the application guide it shows the hole.
I didn't want to go there but its time for zero phucks.
Just gonna reuse the old ones and trim off the parts with holes, rips and thin pressure spots.
I cut the pieces as I held them to a light and its gonna have to do.
I spent a few days digging through pdf's looking for a replacement and now I'm done.
It's the Canadian way to just say phuck it
Dollar store super glue was that call of the day on the nuts. Same on the big caps
IMG_3465.JPG IMG_3466.JPG IMG_3467.JPG IMG_3468.JPG IMG_3469.JPG IMG_3471.JPG IMG_3472.JPG
