I want to attempt to build one but dont understand the wiring yet. Thanks for the links ill check them out
Ok, i dont understand something, i have read this antenna does not need ground plane wires and then i read it does. I want a 5/8 vertical end fed. Do i need ground plane or not? I thiught all i needed is a Matching device? That second link looked to be a 5/8 ground plane antenna.
The term counter poise is not a good term to use in antenna theroy but means the same as radials.
Good luck.
