I have seen wire guys used as top loading for a vertical and also as groundplane elements for an elevated vertical if the guys are of the proper length and insulated from ground but never as ground itself. Actually using guys in the ground path is not a good idea as depending on size they could fail in the event of a lightning strike and cause the whole thing to come crashing to the ground.
