Eddie
This guy is using the SDRplay RSPduo, I have the RSP1a single rx version using the same SDR uno software,
This test is not at all representative of what's possible in local noise reduction
for multiple reasons,
The test is on longwave where his coax & power cable to batteries ( his noise antennas ) are a tiny fraction of a wavelength like using a half inch long coax at 27mhz,
he also puts the choke in the wrong place, it should be at the feed-point for best results,
and the amplified rubber duck antennas are right there next to the potential noise sources hung in the window,
he sees about 3db improvement in the snr where the coax is even shorter relative to wavelength & 6db higher up the band where coax is longer relative to wavelength if you look at the snr display,
much more is available with external antennas & noise from sources near your unchoked coax,
signal strength over distance follows an inverse square law,
you can't expect to see much improvement even putting the choke in the right place when the antennas are so close,
when your antenna is away from noise sources &
your coax runs significantly closer than the antenna to a local noise source &
your coax is long enough to act as a good antenna been usually at least 1/2wave long @27mhz &
you put the choke in the right place,
you can see much more improvement than this guy sees doing the test as seen in the video on longwave with crappy little amplified ducks hung in the window.
And theres more!
He has no mast or ground wire to act as noise antennas near the house like many stations,
If noise is been received on mast and or ground wires which are seen in parallel with the coax braid,
just isolating the coax won't fix your noise,
some people think chokes don't work for rfi or noise or antenna pattern because of the half assed installation techniques most people use,
they make a choke even if its correctly made for 27mhz or buy a line isolator & it seems to do nothing much at all so they don't work,
( RADIALS & MAST ISOLATION INCLUDING ANY GROUND WIRES & CHOKE ) all three together, or you could be wasting your time,
Another reason you did not see much change back in the day is noise from chinashit power supplies & chargers, computers & internet home hubs & such has got MUCH worse over the years,
Hams are packing in with radio because of local noise making operation from their home QTH unbearable to them.
