KF5FUR You should not hit power lines, or have swr issues. As I posted mine is mounted at the front drivers side stake pocket between the cab and tool box. My truck is lifted (44" tires) and I hit alot of limbs and some gas station awnings but I don't even hit my supply line between the house and pole. My swrs are about 1.5 . I always run a spring, The isolator washer will not last without it. Hope this helps.
P.S. I can even catch the tip of the whip in the rear steak pocket for drive up windows.
I went ahead and bought the pot belly spring which brings the length to about 107"-11/16 as measured from the top of the angle mount. Now just gotta work out the Inductive Matching DC ground coil running between the antenna stud nut and grounded close to the connecting location to the shield ground strap that goes to the body of the bed. Like this... (borrowed from K0BG's site)
"The coil at left has 9 turns, is 1 inch inside diameter, and wound with #14 Thermalese® (enameled) wire. The coil's form factor should be kept close to 1:1 (length to diameter). Long skinny coils do not work nearly as well. You can also use building wire, but it is a little harder to work with. In actual use, the turns are spaced a little further apart to adjust the inductance. The coil needs to be about 1 uH, but in the real world, the value may be between .5 uH and 1.5 uH depending on the actual input impedance at resonance." (this is also from K0BG's site) He is talking about mainly the remote control screwdriver antennas but those cover 10 meters on down, so this should be adequate for 11 meters as well, the coils inductance can be slightly manipulated by stretching the coil if needed. Here is a good pic on what I assume is a roof or trunk mount.
While I cannot connect the shield like his on my typical angle bracket mount, I will drill and tap to the hex of the so-239 stud and connect the grounding strap via a crimp end and solder the wires to connector for good measure as well. The coil will connect the same way to the stud nut then the other end will connect to a SLU-70 lug/wire connector to the bed of the truck within an inch of the ground straps mounting with the same lug.
Then I will proceed to check the beds grounding, I remember seeing a while back while under it several straps to the frame for the bed and cab, it being a 03' F-150, it should be grounded like this anyway. I will also check with my multimeter the amount of resistance between the bed/frame, bed/cab, and cab/frame, also add a strap to connect the bed and cab if necessary.
I think I have covered all basis there, lemme know what yall think.
Added note: Many folks think this is a RF short, it is not, it is a electrical short. The inductance of the coil prevents it from becoming part of the antenna. I have seen small coils soldered from the back of a bulkhead connector to the body of a unit, don't remember what the unit was for, but I assume it was the same principle.
-Bill
