CB Antenna accessory: "Zing Ring"
Have you ever heard of a CB Antenna add-on, "Zing Ring"?
  • Total voters
Hi all I purchased a zing ring at a ham fest attached it to the base of Mt 102 whip ribg ontop of the spring. Antenna was mounted in the middle nof my trunk lid of my 66 chevell.. It seemed to help flatten swr across the band helped slightly with output and Recieve. Mada a couple after for friends out of stainless rods most used them on mobile whips nit base loaded but helped with top loaded whips 1 guy used it on his big stick attatched to the base of the whip . His antenna nwan on the 20th floor roof he lived it claimed it helped his output cut down static and flattened his swr across the band.. I still have my original ring was going to experiment with my solarcon MAX optimizer.. See it it makes a difference with anything..
Do you ave a pic?
