I have some doubts here:NC420 said:They were doing about 700-900 watts when those pictures were taken almost a year ago. You have to touch the bulbs to the ant. to get them to light up. If I remember correctly I was told that the person in the pictures was able to walk about 35- 40 ft. away from the ant. befor the lights started to fade out. You have to be carefull doing that though, because the lights can get warm and crack.
Lights are going to crack from getting warm? That seems sketchy since the ionization process creates very little heat in a flourescent tube. Insignificant heat is generated by the tiny filament which stabilizes anyway. The real heat comes from an external starter ballast that might not be efficient.
As for the lamps continuing to glow up to 35-40ft away is also under question. I worked in and around KW and MW transmitter sites as well as 2KW ham linears. The 2KW amps would glow a 4' lamp but not at a distance of even 20'. I'm sure there are exceptions to the rule, considering lamp types/specs, rf radiation levels, etc.
