I like yours even better. That thing is beautiful.I did the same thing with a Sirio 5000
It worked well too right up to the point this antenna took a direct lightning strike 2 years ago!I like yours even better. That thing is beautiful.
Every time I see a mount on a mirror bracket a little bit more of me dies.
I'm still looking for an owner operator with a Volvo 660 to donate these to a good cause since I don't use them anymore.Every time I see a mount on a mirror bracket a little bit more of me dies.
At least rabbiporkschop you know its crap and try to do something to make it less so and it clearly seems to work for you.
I'll give you these free of charge. Made specifically for your truck.It's not that bad. It's not the best place to mount an antenna but for many of us, it's the only place.
Those are nice bracket mounts, thanks anyway. I'm not really into super CB like I used to be and those wouldn't be good for my screwdriver antenna because of the weight and the vulnerability of the mounting location those are designed for.I'll give you these free of charge. Made specifically for your truck.
Been there . . . done that.It worked well too right up to the point this antenna took a direct lightning strike 2 years ago!
Hey 'FatherUncleanMeat' You could try on your SUV what I have on my truck;It depends on the vehicle and the mounting location. Center load is ideal but unfortunately nobody seems to make a center load antenna for a tractor trailer so you pretty much have to make one yourself from scratch like these. These would work great on the roof of a car or truck but unfortunately they would also rip a hole in your roof if you hit a bird at 65 miles an hour.
A center load on a tractor trailer still won't perform anywhere close to how this bottom load performs on my Chevy Tahoe though.
I recognize that a top load or Center load antenna would be more efficient but with that huge sheet metal roof I can afford to compromise with the bottom load and look very inconspicuous yet still have great performance. I'm trying to look as Incognito as possible.Hey 'FatherUncleanMeat' You could try on your SUV what I have on my truck;
a Quad-magnet mount
...Which I use for my custom built 'monkey-made' style "center-loaded" mobile antenna.
The cool part of the "center-loaded" antenna, (of which many or even most aren't actually centered) is the way the load raises the current bloom up & away from the ground of the metal roof, providing a lower TOA and less of a 1/4 wave GP effect of a ~45° TOA, helping the overall performance when long-range local or low-angle DX is preferred over higher angle 'canyon" performance.
When I head for the hills to go camping and I know I'll be in & outburgerof canyons, I'll swap to the Wilson 5000 mag mount.
No doubt it did!Been there . . . done that.
Guaranteed to make you change your shorts - lol . . .
not really But in off-road situations with tree branches to deal with and a roof that 7 ft off the ground I don't need something rigid attached to my sheet metal that's going to get taken out by a tree branch, plus with the Invasion from South of the Border I don't need to attract attention to any electronic equipment I might have in my vehicle by having some big gaudy looking antenna on the roof of my vehicle. When I'm in a tractor-trailer I do things completely different by measuring the physical space I have to deal with from my desired mounting location and subtracting the length of my load and dividing the remainder by 2 which tells me how long to make my shaft and whip. I can create a much more heavy duty antenna mounting system on a tractor trailer than I'm able to do on a sheet metal roof so that my shaft will actually Bend if I hit a bird at 65 miles an hour. if I hit a bird in the Tahoe it's not going to damage my antenna due to the flexibility of the whipIs this an admittance you're a "CB Rambo"… ?
