Wish I would of had some electronics training. I can fabricate an repair all kinds of stuff but radio circuitry is not my line. Guess I'm just a User. LOLIf it's a standard 40 channel SSB radio, yes we used to unlock them.
A lot of these fellas on here really amaze me of their skills working on the radios.Wish I would of had some electronics training. I can fabricate an repair all kinds of stuff but radio circuitry is not my line. Guess I'm just a User. LOL
got that rite andyWell, honestly?
IF you can keep the PLL signal from "offset" (that 455kHz Shift in some strips) and keep the Clarifier Xtals THE SAME and instead of using switch contacts, use Diode and Electronic switch (Galaxy does this to a certain degree) and a strong (read amp-ready) 3 amp regulator that REGULATES - then the world can speak and hear on the same frequency all day - but this is a different world nowadays, there are those that; if you don't sound (or act) like them - they simply will not answer you...
There are two threads in this thread - ones that are more than happy to tell you how their day went, and others that simply don't want to talk to you for if given the chance - they will unleash (for days it seems) the errors of everyone elses' ways and why they are where they are.
Wars have been started over less.
Ah the SuperBase,one of my personal favorite rigs of all time.Always wanted one but never had one. I have a 2547 in my shack that was checked it b4 it was put on the air and yikes! It was ok on am but really way off on SSB,the main reason I bought it. Unlocked the clarifier and aligned it and today it's a different radio. also it needs to warm up a little b4 you start talking if ya do this it stays pretty well on frequency and doesn't drift much. Good radio with a bit of TLC. 73 BobI have a Galaxy DX 2547 I bought brand new that was suppose to be unlocked but I never really made any contacts with it but it got moved off my bench because I bought a Cobra 2000 shortly afterward and played with that and then a GE Super Base after that. I have to get the 2547 back on the bench and check the transmit alignment. I have to find someone close that is good with alignment so all my radios are set up proper. I have too many Irons in the Fire to try it myself and make them worse.
Which is very rare condition with CB rigs.I like unlocked...but only if the RCV and TX frequencies are tracking correctly. Otherwise even in a 2 person QSO you will wind up chasing each other all over the place. This really needs "good alignment" on the part of all participants.
yes the PLL needs to be set to the proper frequencies, but what defines a rich sounding radio from a thin hollow sounding radio on SSB is how the IF is aligned. aligning to exactly the service manual specs is not necessarily the way to do it.
I forgot to add that I was talking about cb's and not the exports.Ilove my Galaxy radios, [I have 3] but galaxies are useless on SSB unless you realign them and unlock the clarifier.
It's a personal preference thing.So much stupid having it adjust both RX and TX together with the one control. If you have it so your clarifier alters your TX as well as RX then when you adjust your clarifier to receive them better your TX frequency changes. So they then end up adjusting their clarifier so you sound better to them but that then changes their TX frequency so again you're adjusting your clarifier on the next over so they sound right which also changes your TX frequency, they adjust so you sound right which then alters their TX frequency, rinse and repeat until one of you hits the end stop of the clarifier control.
