An external SWR meter would be the fastest/cheapest way to find out. A better way is to use an antenna analyzer; but that is quite a bit more costly.
I've had two K40's that had bad caps in them. One of them I got that way; the second I popped myself. Seems that they don't like amps that put out more than 250w before they pop. Been there; done that.
Be sure to mount your antenna/mag mount on the center.top of the vehicle before you adjust it or check it. You will find out if the cap is bad if the antenna's SWR can't be adjusted by changing the whip length.
hmmm i guess il just get another meter if you cant tell by the recieve or tx. i havent connecting a burner so if it is blown its not
by me. i was just curious as rx is a bit strange but i think its the area
i live and im not used to it fluctuating so
much as i just recently moved here.
this ones actually mounted via the hole mount system but on a k40 stainless right angle mount bolted directly just above the gutter on my truck so i can simply reach out and remove it.
i did think about fitting a dv type 180 degree swing mount and something on a standard thread or quick release bayonet style mount
(like euro home light bulbs fit)
but i guess thats a tired out subject for a new thread.
