Your running a Galaxy 98-VHP and you can only talk 5 miles? You got some issues to work out for sure. Just adding a second antenna is probably not going to save the day.
One would want to state conditions. Far West Texas at night is one thing. Almost all else has terrain or population-density-related handcuffs waiting. (And I’d install co-phase any day to help with trailer-related problems; highway distances really matter).
I don’t think a high-powered radio is the determinant nearly so much as big trucks with poor antenna mounts is a constant problem in need of solution.
The single biggest improvement I’ve experienced— where the install was professionally-done with ALL new gear — was on a Peterbilt 367 (west coast mirrors as with the FLD) running a DX-99V2 and I made the leap to using a West Mountain Radio CLEARSPEECH DSP Speaker.
Other men in identical trucks running installs as nice as mine or better
simply couldn’t hear a number of distant others with whom I could converse as we ran the oilfield together.
That I regularly hear RX from 10-12 miles (sometimes farther) is condition dependent, but not unusual. (Haven’t said it’s all-the-time).
Well past five miles IS a regular thing.
“Five miles” may just mean signals strong enough to overcome high noise levels per big truck deficiencies.
I regularly key up and try to speak to Big Radios I can hear, but who cannot hear me.
In big trucks
an amp and
DSP audio is employed
to overcome the other guys radio rig install deficiencies. But the typical big truck “good” antenna system leaves one a bench warmer when the Skip or Sideband game is underway.
One of those devices without the other — amp & DSP — isn’t a help in communications. Get off the 4W floor, sure, but have the signal clean-up to take advantage of 50-150W range for typical road-related problem discussion.
A big amp — and wanting to play Skip or talk Sideband — is going to require an antenna mount and antenna tuning past “best” for what most
smart operators typically employ.
I bumped a Sirio antenna thread where contributor
fourstringburn had what may have been an antenna set-up (if I recall correctly) able to do a good job on Skip & Sideband.
There’s
CB (typical AM) and there’s the rarity:
SSB or
Skip where to be included
as a regular player in the mix requires a new antenna approach and more work. The
Eleven Meter Capable Radio System versus the typical big truck amp’d CB.
— “Five miles with a DX-98VHP” isn’t uncommon in big truck mobile-to-mobile. It just doesn’t require big watts so much as an okay antenna system if RX distance is the measure.
The operator lacking DSP may not be able to hear past that (conditions).
The big wattage isn’t adding anything without the DSP ears (on one hand), and (on the other hand) one needs a
much better thought-out antenna system to meet the Skip/Sideband test (as it appears to me a worthy goal).
