dont worry about it, it's 2m FM... FM... FM... FM get that antenna as high is it will go... in the upper HF (12m, 10m), VHF, line of sight FAR out weighs the losses on the coax...
NOW if you are doing a VHF SSB setup... well thats a little different... then you really need both
when I was running a 8 foot colinear 2m/440 vertical at 30ft I could barely get out 25 miles on 2m FM simplex... however getting up to 45ft make a huge difference, I could hit repeaters over 60 miles out with 5 watts full quieting and works FM simplex about that same distance on 50 watts... even though I had increased coax loss from running 75 feet of mini 8 coax
if you want some cheap low loss coax get yourself some Cable TV HARD LINE!!!
