CDX197 said:
with your amps i think you wont see to much of an improvment though
BS.
I have been over 30 DB on the bowl with my 2 pill. And i know i can get out. Dont tell me i cant get out.
As in Bleeding, Um not a problem on this end but on the other channel it might be a problem!
PS W5 i have no dought about my setup. Just wanted to know if my coax will work. (Dont want to crawl up a tower thats only about 1'5 wide. If you know what im sayin
197...No one said you aint getting out...He just said you wont see much improvement over what you have now, by changing coax. In other word's, you will still hear about the same, as now, but by useing 213 or one of the other coax's mentioned, your signel may not interfear as much with TV's, or other electronic stuff, because it's better shield'ed.
As for "bleed-over", you dont know if your system is bleeding or not, unless someone close to you, tells you.
"Bleeding" is when your talkin say on channel 28, but folks on channels under 28, and above 28, can hear you, on the channels they are on....This is a comond problem, when useing Amplifiers. But by useing some of the better shield'ed coax's, you can cut-down on some of the bleed-over, caused by your equipment...And dont think your system doe'st bleed...all of them do, to some extent...
Now If it were me, and I was going to go through all the trouble of putting up a new tower...I would deffently use "New" coax...but thats me...Peace JJD
