Coax
Here we go again!
LMR-400 is the ticket! You could also purchase CableXperts CXP1318FX here;
http://www.cablexperts.com/cfdocs/cat.cfm?ItemGroup=2&itmsub=0&bskt=0&USA_ship=1&c=0
There is no "double shielded" RG-213. There is a double shielded RG-214 which is MUCH different than RG-213. RG-213 is old technology! You are better off running LMR-400 or the 1318FX!!
Why? LMR-400 and the 1318FX are double shielded, have a higher velocity factor (less loss) and a non-contaminating jacket! If you buy the ready made cable from CableXperts, you will also have PROFESSIONALLY installed connectors of your choice that are sealed up with UV resistant shrink tubing!
"The best money you can spend on your radio system is on the FEEDLINE and ANTENNA!"
BTW, 2 driving 4?! Nothing can help you with bleed over with that set up!
Reactions: Groundhog KSS-2012
    6m SUKS today damn...lousy condx...did work FLA but still PB "Pretty Bad" :love: :mad:
    list'n 50.125 USB...working in shop...also 2m FM Simplex freq's 6.52...6.46 ... 6.55 etc..:ROFLMAO::coffee:
    Called you twice Mr. G.......................
    I was look'n your way Evan...was working on some lighting in the garage...you were just "Thr" but w/ fade...you were gone...so did not fire the heater and call :cool:
    Roger that, 6m on the HexBeam is lame.
