Hi All,
I recently picked up a Cobra 140 GTL (Uniden PC-385 board) and was in the process of bench testing it. When I first started testing it, I thought the squelch was malfunctioning, but I'm beginning to think it is something in the audio chain instead. Here is what's happening:
When the radio is on, you can hear a white noise similar to static coming through the speaker. This white noise is present whether the squelch is turned up or not and does vary with the volume control.
For example, if I inject a 1000hz tone using my RF signal generator into the radio, and monitor the audio output on my oscilloscope, I can see the 1000hz sine wave. The amplitude of the wave is varied by the volume control as would be expected. If I turn the squelch clockwise until the signal generator tone is muted, I still hear the hissing sound similar to static.
The hissing sound remains and can be controlled by the volume control.
Any ideas?
Thanks.
Any ideas?
Thanks.
