That's what I thought I had read one time. Talks great on AM, but no SSB. Basically made a cobra 29 out of it.999 beat me to it, The AMC and ALC are both defeated if you do this.
Go read this whole thread before you proceed.
Good info in this one there is.
Cobra 148gtl r131 removal?
So i need a solid answer here. On the old cobra 148gtl radios, 5 pin side mic made in Taiwan, if i remove r131 does it disable the modulation limiter completely, basically same as removing the transistor. Or does it keep the modulation limiter function working, with just a boost in am modulation?www.worldwidedx.com
Wow, that is some kind of long winded post, but great information, just hard not to get lost in it. Looks like I need to buy me a anywho ares II, and sell it back to fleabay.999 beat me to it, The AMC and ALC are both defeated if you do this.
Yes, I seen that about moving the TR26. I will have to open it up this evening when I get home and have a look. ThanksCliff notes version:
Go find the post by Nomad in that thread about removing TR 26 and putting it in place were TR 24 should be.
This should allow you to at least control the ALC level on side band even if the AMC is defeated for AM.
If you have NO ssb at all, then that's a different question.
