Damn Handy Andy, thats specific instructions right there. Im absolutely confident he will get it fixed with your help.
This may not be over.
But as a warning for others that own these radios that have not been recapped yet, this specific repair may cost you a pretty penny trying to fix it after this condition.
I've seen this happen when people first try to turn on a radio that has been sitting for years on a shelf.
If it takes more than a second - or two - it may be too late and you can't stop it from the failed boot fast enough for the power supply caps will dump their charge into the mess and let all the magic smoke out even if you manage to turn off the power.
It deals with old caps - when they dry out - and then power is applied, they will "gass" and even deform - causing the plates to shift - if ever so slightly because of the increased pressure - the package may survive the surge but the bulge, if it's excessive - will destroy the plate foil wrap from deformation - shorting them out.
This can force a shorting condition and VR10 - if set anywhere but mid-point - can send power INTO that cap that is now shorting out - and VR10 being directly fed by the 8 volt MB3756 CONSTANT via pin 1 - will dump at least an amp into the pot and potentially pop the pot open like a fuse and render the circuit dead
That's' why I said - if it takes a second or two to even "turn on" - even to light any panel lights, that delay, it may be too late.
- - all because the cap (any or all subsequent after) pulled all the current thru the substrate and due to the wattage rating the pot is (about 1/4W - 1/6th on later boards) it can blow open and you get no AM power - no way to turn on TR42 except for audio drive.
So if one cap blew, it can even take out the Audio amp from the apparent "dead short" condition or prevent the power from passing thru. CB/PA switch is also affected - the audio amp is capable of pushing several amps into the switch - the caps are to prevent this from happening.
It can even affect the PLL and prevent a "lock" condition takes too much current to keep the line "logic level High" enough to keep TX working - caps on the line used to keep the PLL from "false triggering" (a filter cushion) will just hold it low and no TX can occur.
So if the power switch is on, but the lights won't come up - shut it off and hope no wisps of smoke emanate from the vents - just make a plan to spend time gently resuscitating the chassis by recapping.
Cheap insurance.
He's' getting SSB, just worried that TR42 or VR10 are goofy...or the Mode Switch pole that the finals feed from - popped open from a poor "jumpered final" mod. RWOB.
- RWOB? Another story for later - it will take some popcorn to help offset the duration of time the story takes to tell...
Here's the "logic" as to why I posted this...
