I am seeing an issue so I was probing around and checking some Test Points and I’m seeing 2MHz on TP3 on USB and CT2 does nothing to affect TP3. This radio wasn’t working from the beginning and I found a few issues, it had the clarifier mod that I removed it was just sloppy and I don’t need. So it was keying around 1.2 watts and would slowly drop down to 0 watts. I found someone removed V10 & C186 we’re just missing. I pulled an old V10 from a parts radio and installed a new cap and now it sits at 2watts no drop off.
I was originally seeing and still do see channel 1-13showing normal frequency but 14-28 are all wrong the 29-40 are good.
I believe this may be associated to TP3 not getting 7.8MHz?
So what direction should I start testing I’m not sure where TP3 actually gets the 7.8MHz from? I did pull the 7.8MHz crystal and it’s showing 7.8013MHz that I assume is fine.
Andrew
Andrew
