Is there a modification that can add a 10k slide switch to a Cobra 29 and or a Cobra 25? I haven't been able to scare one up on the net. Thanks in advance. RF
I'm guessing you don't completely understand the problem.think one correct way to accomplish this is to build a 5.12 mhz oscillator and replace the signal from the pll going into L19. Then pull that with a varactor.
Okay Let's see why any of this works...1) a 15.350 crystal oscillator injected as per the Expo instructions.
This just shifted everything down 10Kc
How much slide will this give?View attachment 36632 This is listed for a 29 GTL, but it looks as if it should work for a 29 LTD.
There is no 10.695 oscillator in the 29 only 10.240. The 10.695 is generated for RX by shifting the n-code down and mixing that with the incoming 27m15.350000001+.91+10.695=26.955000001
Sue is about good as they come.One mod from a year back on T1 for the cobra 29, gives low 40, high 40, 5kc shifter switch and 10kc shifter switch with $20 worth of ebay parts.
https://www.transmission1.net/viewtopic.php?f=53&t=56500
Which 25 or 29?Is there a modification that can add a 10k slide switch to a Cobra 29 and or a Cobra 25? I haven't been able to scare one up on the net. Thanks in advance. RF
