DTB Radio said:anixon said:thanks switch kit. just add the ekl 2030 &1230 with the 68capacitor and make adjustments.
If you want to get the max, it will be a bit more involved than that, but the CB Tricks mod will definitely get you a lot of extra modulation and power.
after all has been said and done on my bench , there is a lot more to it then what CBTricks has to say about it , (this was brought up in the tech section under mosfets) I found them more to act like a swing kit , low DK at 2 with just over 30 watts pep with audio off the scale )-: but you can bring the audio down but you better believe the 30 watt pep will go down with it. More work surely needs to be done as DTB and Bushwacker stated in the Tech section of the forum. And even after the extra work as was stated , you would only be looking at a 5 to 6 watt DK after all was said and done. These are nothing like the 1969 mods NOTHING ! and after finally getting around to do one myself , I wasn't impressed so far. For those with limited knowledge of these mosfets (like me) and one thinks he or she can just go out and buy one of these 10.00 mosfet kits for a Cobra 29 or 25 and your looking for a higher DK (which I personally think is what most folks are looking for when they get these) you will surely find out that's not the case and CBTricks does not go into futher detail on the instruction page , you will need to futher search the site for better results with these , that's if you can find them ? Cobra 29s and 25's will do 5 to 6 watts and swing anywhere between 20 and 25 watts pep by themselves , so for you's looking for more up to this point , save your money and time and just have your radio tuned and leave it at that. With power in perspective ......is it really worth it ?
