Condition of components...I picked up a 29 lx that blows the fuse when you hook it up. I checked the polarity protection diode and it looks fine. What else should I look at?
Cobra 29 LX blowing fuses
If it's getting paid it's regulated in most states if not illegal.
If it's mutual consent and not for profit , what business is it of yours?
I clipped d26 I believe. That's what I read some where on google.did you clip d23? make sure that is the one you clipped. did you try power to the radio after clipping it. you said you show continuity which you will still have some when using a ohm meter to check the power leads. here is then schematic for the 29LX radio.
http://downloads.cobra.com/CB/Models/29-SERIES/29_LX/29LX_schematic.pdf
Please don't forget to replace it. It serves a purpose - saving all of the silicon devices from being shorted out. Cheap protection @ $.05/ea.I finally found it. Clipped it and there is no longer continuity between positive and negative posts
