COBRA 29 QUESTION
I agree with you Mole, it does look more like the A 99 set-up.
(this was supposed to go under mole`s post above)
CDX 339
RadioActive
</p>Edited by: <A HREF=http://p067.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=audioshockwav>AudioShockwav</A>
at: 9/29/04 7:07 pm
There are many different types of matching systems used in antennas. For example you could use a gamma match or a beta match on a 5/8 wave vertical groundplane. Just because you use one or the other doesn't change the fact that it's still a 5/8 wave vertical groundplane. A 1/2 wave dipole is USUALLY fed in the middle, but it does not have to be. If you doubt that, I suggest you get back out your ARRL antenna book and argue with it first, instead of everyone else. Just because the A99 uses a slightly different matching system than the diagram I showed you, doesn't change the fact that they're basically the same antenna.
</p>
