You're doing absolutely everything wrong, even running the negative wire directly from the battery which is an absolute no-no yet most people do it.
Please elaborate. How and why am I doing everything wrong captain?
In regards to my negative power line, please re-read my post. It is not coming from the battery. It is coming from the metal body of the car. However, even if it was coming directly from the battery terminal, why is that considered wrong and how does that impact the system in a negative manner?
Low SWR does not equal efficiency. Don't be fooled by thinking a low SWR means its working properly. You use a MFJ antenna analyser. What does tell you how efficiently it is working is the value of R when X=0, the resonant point of the antenna. Should be 37 Ohms for a perfect installation. Anything above or below that shows you've got losses. If you're getting near 50 Ohms where X=0, you've got a whole lot of losses.
Agreed!!!! Quite honestly I don't remember what the efficiency was. I think it was +/- 50 ohms while resonant on my center frequency. Can you please explain why R or the resistance should not be 50 ohms and rather 37 ohms?
Jesus!!!!! Just when you think you know Jack someone comes along and makes you realize that you only know of Jack.
No idea why you need an amp on the Baofeng. 10W on my installation in my car gets me 60 miles easily.
I don't know how you are getting 10W out of your Baofeng . Which model do you have? I have both the 5R and 82 model and both put out around 3W to 3.5W even though the 82 is suppose to have a little more juice. The only repeaters I have hit without the amp is about 15 air miles away and unfortunately there is no others around here that are within 20 to 50 mile range to test. To me, 60 miles sounds reasonable with about 10W on VHF/UHF. And let me tell you... I know this because I am very knowledgeable. Something tells me that you are not using the factory antenna which by the way, I tested it with the antenna analyser and sure as heck, it's their POS version. Was not resonant anywhere from 2MHz to 175MHz. Maybe on 70cm but not on VHF.
Excuse all the questions. I only have all the radio gear and test equipment. I am trying to learn more about this hobby so I can start using everything properly.
Never watched any cop shows hey? MO= modus operandi which means the way in which someone characteristically does something.
10-4. Copy that.
No.....not really. In fact he was somewhat of a real dickhead troll actually.
Huh!!!!! Sounds like he/she is a really cool cat.
But really though....Dickheads can be smart people... On the other hand, you are right they just think they are and my brother-inlaw is the perfect example of that....
F#&*ING DICKHEAD. I promised myself that everytime I thought of him (my brother inlaw), I would use the word dickhead.
