I believe my T1 (EI 28) is bad but would like to test it. I removed it but not sure how to check it. I looked at the data sheet but I’m not sure? I found D8 cracked.
The issue is 0 output when I key it goes out of RX but no TX light or output even if I connect scope directly to coax.
