Ok guys/gals...
Got a Cobra 2000 GTL on the desk.
Issues are:
1. No transmit whatsoever.
2. Constant static in speaker, even with volume turned all the way down.
When turned on, with mic connected and volume all the way down, there is still a lot of static in the speaker but you can't hear local stations. When the volume is turned up, then you can hear the local stations but that static is still present.
No sign of transmit at all.
Checked collector voltage on both the driver and final, along with collector of passthrough regulator, all seems normal. Removed driver, final, pre-driver and pre-pre-driver, tested all with no issues. Replaced the 2 bias electrolytes. Replaced the choke next to the driver bias VR. Replaced bias VR itself. Checked and replaced C95. Checked R108 (98.6 ohms). Replaced C18 (value was well below range). Checked over solder joints. Everything looks good. Final bias adjusts fine, but I get nothing from the driver bias.
Final bias - 70ma (adjusts smoothly)
Driver bias - 0ma (will not change)
Any ideas?
Issues are:
Any ideas?
