Then look at the stages with your spec an. See what is making power and where it stops. I still think your driver and final are suspect. The collector voltages drop way down in TX. Just be mindful of the max input of the spec an. Use a power attenuator in front of the input if necessary.I think I have the equipment I need.
Spectrum analyzer
3 oscilloscopes
2 frequency counters
2 signal generators
Desoldering station
ESR meter
Capacitor meter
2 multimeters
Component tester
Just need some guidance on this issue.
Can you send photos of the two devices that are (were) in the radio that came from eBay? BTW, I don't even try to use Mitsu, NEC, Toshi parts any longer. I change to MOSFET. The fakes are not worth the hassle and the HG parts suck.Check between the legs. Here is a legit 2166 vs fake 1969. There should be tits between the legs of the legit. That's another way I use besides the markings.
An easy way to tell fakes from real parts is to look at the surface finish. The fakes often have the face burned off with the same laser that etches the new fake number into them. Very few take the time to polish the face after removing the original markings. The laser will almost always make the face look matte compared to the rest of the surfaces. Cable Guys picture illustrates this well, look at the 1969 finish.Check between the legs. Here is a legit 2166 vs fake 1969. There should be tits between the legs of the legit. That's another way I use besides the markings.
Well, got the transmit working great again.
Replaced driver, 2166 (it was original, had tips between legs) with a 1306.
Reset bias for 30ma on driver.
Reset bias for 70ma on final.
Realigned output stage
AM - Deadkeys 2.5w, swings to 18w peak, swings up to 6w in average.
SSB - 25w peak
Sounds awesome on monitor radio on same frequency.
Now just gotta figure out why there is static coming through speaker with volume turned all the way down. When I turn volume up, I can then start hearing local stations but still has that static noise in it. When I turn volume down, then the receive volume drops down but that static noise stays in there.
Gonna clean up this flux from bottom of board (mainly in front of and around the 3756 and 7222 ICs.
