COLOMBIAN AUTO REPAIR
unit_399
EL CAPO
Jun 17, 2008
2,307
3,722
273
ALEJANDRIA, COLOMBIA SA
What can I say ??? ..... at least it worked long enough to get it to the shop, where it was probably repaired with rebar or plumbing pipe.
- 399
Reactions: Robb
hey, you do what you gotta do. I "fixed" a friends car that had the trunk rust out until the leaf spring popped through. we jacked it up and put a tire iron through the spring bolt hole for the body to rest on. worked fine for months.
I had a throttle cable break one night, so I ran a 14 gauge wire from the carb, through the hood/fender gap, and in through the driver side window. got me home and 50 miles round trip to the parts place the next day.
Reactions: BammBamm
Wait'll more pictures start coming out of Cuba. I remember a set of pictures of home-made fixes on their old cars some years back. I clearly remember a tree branch - with leaves still on it - be used as a replacement for a, ahem, rear leaf spring. :eek: On like, an early '50's Chevy Be Air!
    535A has left the room.
  • @ AmericanEagle575:
