Ok, any u guys running one of these antennas ?...
If so, how do you like it ?...
If not, how about one of zerofive's other antennas ?...
neither of those antennas are really going to outperform the Maco v5/8
A Little over a Year Ago, I was living up here in the Sierras , down in a little Valley.Posted By Marconi:
As far as performance goes, all the antennas I have here and compare, my results show them to all be within 7-7.9 average sunits of each other. IMO, that is not enough difference to ever make you loose or gain an advantage with a contact. Other conditions might make that difference, but overall when all is said and done, these vertical antennas are just too close to the same performance to really tell...just using our radios. In fact several prominent radio guys have done technical studies for the comparisons between 1/4 - 5/8 wave vertical monopoles and found this to be true also.
The right Antenna is the one that works for your location, and the one that makes you feel it was money well spent.
There is the correct answer to all of the antenna questions and wars.
Yes you are correct, but you will never find any 5/8 that will show that much gain difference among the models we are talking about.7 to 7.9 Db makes a BIG difference
No, I don't think so.Posted By Marconi:
... huh?????? am I reading that correctly?
7 to 7.9 S-units makes no difference on RX?
I'M not really sure exactly what an AVERAGE S-unit really is
7 to 7.9 S-units
Marconi takes several readings and averages them. I think what he is saying is that of the antennas he has tested, they've all been within .9 S units of one another ............ I don't see any mention of dB.
But how do you know that Marconi's installation isn't the exception to the rule that different designs and lengths antennas will provide more widely different performance?I did not take time to find the post but he is talking about Readings he was taking to stations that are around him......
There is an Approx Difference of about 1 s unit.
I will see if i can find it.
