I want to run cophased dipole antennas on my truck. I'm currently running a single dipole, and have been mostly happy with the setup. My current antenna is mounted to the driver side mirror bracket. This leaves a "deaf spot" on the passenger side, rear of the truck, that I would like to eliminate. Also, for some weird reason, my antenna hums loudly, when I am driving at about 40mph. When I say it hums, I don't mean that a humming noise comes from my radio, I mean the actual antenna hums. It doesn't generally bother me, but it does annoy the wife.
So, what I want to do, is mount dipoles on the grab bars, on the rear of the tractor. Having flipped the grab bars, I can get the antennas out from behind the cab.
The antennas would be approximately 8 1/2 feet apart. It would take about 20 feet of coax to get from the radio to the driver side antenna, and, depending on how I run it, between 20-26 feet of coax for the passenger side.
I have 2 102" whips that I intend to use as the top half of the dipole, and will most likely use a 4' 1/4 wave fiberglass whip for the bottom half.
Also, in between the radio and antenna, there will be an impedance matcher, an amp, and an swr/pwr meter that I like to keep inline.
If anyone has any tips, tricks, suggestions, or advice, I am open to hearing them. I may even begrudgingly accept constructive criticism, lol
