Dealer - if you do wind a choke for keeping RF off the outside of the shield, you might want to keep the diameter fairly large. A good rule of thumb is to shoot for a bend radius of 10x-12x the cable diameter. For RG8, which has an OD of 0.405", that would be a 4" radius, or an 8" diameter. In hot weather, if you flex a piece of coax too sharply, the center conductor can migrate right through the dielectric and contact the shield. This is generally considered ungood. Keep it loose!
_____________________________________________________________________________
The choke is at the antenna end, wound appx. 5 1/2 inch I.D. using RG8X.
I left about 20 to 24 inch length to hang it under the 4 to 1 balun using
a messenger line at that junction.
Feedline to start with is 100ft. RG8X and brings up another question..
Will I need to consider these chokes as added length to the feed line ?
Guess I need to do some calculations of V factor on that one, however not sure
what frequency to figure since it is more than a one band antenna.
Dont want to get feed line at a No No length.
Spoon feeding is not necessary..
I hear get ready for work calling
Regards,
John
