Retevis is giving away Radios for the New Year and Every Member is Eligible. Click Here to see the details!
Could you describe what kind of wire that is and the components under the blob?
Pin 2 already has a cap it's connected to. I'm wondering why the extra cap?
http://pdfdata.datasheetsite.com/pdf1/ST/TDA2003V.pdf
BUILT-IN PROTECTION SYSTEMS Load dump voltage surge
The TDA 2003 has a circuit which enables it to withstand a voltage pulse train, on pin 5, of the type shown in fig. 19.
If the supply voltage peaks to more than 40V, then an LC filter must be inserted between the supply and pin 5, in order to assure that the pulses at pin 5 will be held within the limits shown in fig. 18.
U505
VOLC is supposed to be where the fix's other end of the jumper is soldered to. Disclaimer:I'm still trying to figured out exactly where this fix's jumper goes too so don't take my word for it just yet.
Discord is great for playing games and chilling with friends, or even building a worldwide community. Customize your own space to talk, play, and hang out.
