Hello, I am new to this site and hope I have the correct forum to discuss this.
I read an old thread from 2005 but still need help ...
I am going to build a 4 Element Cubicle Quad Antenna and I am looking for someone with knowledge they could share about some technical questions I have, so here goes:
My Background -
In 1971 I built a 4 Element Cubicle Quad ( Not the same type as a Moonraker that is fed from the elements ) the type that is fed on the outer copper wire; so all my questions will be about that type of Base Antenna. I had a book that gave me specs and I had to order a Balun coil about the size of a silver dollar coin with a hole in it that I ran the coax around twice. It was a long time ago, I served in the Army 23 years, moved a lot, lost the book and now that I am semi-retired would like to build another antenna.
I ordered the book by Wm Orr about Cubicle Quad Antennas and will receive it soon; in the mean time I read online about the 11 meter Antenna builders info and remembered 85% of it from 40 years ago, but some things I need help with:
1. In the diagrams on the 11 meter antennas for Cubicle Quad it shows the driven element wires being fed at the coax with the inner part of the coax ( Pos ) on one end of the outer wire - and the other end of the same driven element wire being attached to the outer part of the coax shielded mesh ( - ) OR
the two ends being attached to a fancy Balun cone shaped thing that looks pretty nice ( instead of the silver dollar sized balun thing I originally used ) //// I don't really remember how I fed the antenna 40 years ago but thought I put inner coax on one end of outer element wire and ground side of coax to metal horizontal boom pole which was grounded to the mast.
Help !! Which way to feed it....
2. Rather than make a Balun - I guess I will buy one of those cone shaped ones with the eyelets .... man do they have a lot of choices.... See item # 5
3. Since the radiation is fed on the outer wire, the middle horizontal boom pole that supports the 4 elements would not necessarily need to be grounded would it?
The reason I ask is - I considered making the boom out of PVC Schedule 40 and supporting it with one center pole sticking up and non-conductive rope lines going down to the boom pole. Years ago I used a chain link fence pole as the main boom pole which was grounded, but PVC is lighter.
4. If I use PVC sched 40 do you think I would cause more noise due to static on the PVC boom pole / Antenna?
5. I have a Ranger RCI 10/11 meter radio and would probably not use any more than 500 watts on the Ham side and of course 4 watts on CB ..... but would like to build the Antenna to last; not sure about 50 ohm or 75 ohm coax; probably run about 120 feet of coax and be approx 60 feet above structure or ground.
I appreciate any help you can give me specifically concerning the old style Cubicle Quad Antenna -
IF you want to tell me about how a Moonraker type would be a better option - I Loved the old Moonrakers but can only build one at a time so I am going to build a Cubicle Quad this time. I also don't want to get a Quad that has a brass matching plate built into it.
Thanks
Jessey
My Background -
Thanks
Jessey
