Hi,
It was laying around for years without tubes except the little tube for the key Up circuit.
Ah over a decade ago re-tubed to 24LQ6 3 Phantoms with 12volt relays & PNP TO-220 high side transistor switch. regulated DC 24v filaments.
Perhaps pre-Alzheimers. forgot a lot of tube theory.
This beast uses 2x110v DC relays. Measured from the low side of the relays a staggering 187v DC !!!!
Grounded to Chassis. The schematic on CB Tricks is for the transistor key up circuit and 12v relays.
Probably can sketch this version's original circuit if I had to.
Changes I made. Full wave Bridge Doubler connected to a DC to DC Boost board giving me a steady 31v
DC filament voltage for the NOS 31LQ6.
Thermisitor and delay relay board which switches out the thermy then current flows through the relay. 15Amp
push button circuit breaker.
Cool large green led meter next to the filament switch. The red on light is now between the lower load & tune.
The + - of the bridge is floating above ground I think. 2x 10,000uf Elna for the doubler. 1x 6800uf elna for the
DC buck board output. The board itself has a lot of parts caps & 2x regulators heat sinks. Rated at 6Amps to 40v Dc Adjustable output. "10x 31LQ6 requires 4.5 amps at 31v
For the red on off light to work & the relays. 1 side of the AC input to bridge is still connected to chassis.
Also for the key up Tube Filament. One center tap was never used & still not. The others still connected as originally found.
I get the 12v for the soft start relay board from 1 diode & 100uf 16v from one AC side of the Bridge rectifier.
I changed the Very Old Leaky HVcaps to 120uf Nichicons.Skinny & short. Needed the space for the buck boost board & related Capacitors.
Tested Amp with 6LQ6. Went to 3 amp Diodes tested Amp again. Changed out all old capacitors.
Checked again. Did the conversion to 31LQ6
Here is the problem.
1050v DC is applied to the 6 31LQ6 finals Plate on Key-up. 550v is applied to the four Drivers. Switches on High. 250Watt switch off Lo power off.
No output or Amplification ? The cb radio 4 watts simply get lost. I can see a hair of movement on the Co Axial Dynamic meter. SWR between radio and Amp sames as when driving the original 6LQ6s. Acceptable and the same when the Amp worked with original tubes,
It is a - bias problem obviously. Grid number one ? Or is it a Cathode bias problem ? The BJT Phantom Schematic shows a few similar parts placements. Grid tune stands out. CB Trick Schematic is three Stage.
The one I have may have been a three stage. But I think it was turned into a Two stage not sure. Pink
wire DRIVES me crazy ! No color code. At least the mains wires have colors ?
. 3 wire prong conversion using a "gimick" at the ground of the three wire. This gimick connected to the D&A meters. One center tap connected here with resistors & Disc Caps.
My model did not have chokes like the CB Tricks schematic from pin 1 control grid to ground on some tubes.
All 10 tubes in my model are grounded grid. I took all 6 filament wires. Put them in proper phase.
Center Taps of HV supply to chassis thru large disc Capacitors are original. One filament center tap drives the RED on Off lamp.
My feeling is I have to make a Bias Supply for control grid one. For the life of me I cannot understand how it is biased with the original tubes.
Any help Appreciated.
Would like to get this Sweep Beasty working ! It actually worked with a batch of worn out 6LQ6s.
Till I golden Screw-drivered it !!!!!!!!!!!!!!!!!!
I also have a Working Warrior that I can re-tube. If I can finish the Phantom?The Warrior ought to be a Breez !
Only Six tubes more ! Ive had this batch of 31LQ6's for years.I finally got around to it !
Best John Any help appreciated.
