i have posted this before, but i like to post this info when i come across a D104 thread in hopes of saving a few of these precious mic elements from the trash can.
if you believe your MC-320 element (or any standard D104 crystal mic element)
has gone bad, DO NOT THROW IT AWAY IR OTHERWISE RUIN IT!!!
there is still a chance that the element is still good, and just needs a little TLC.
see, the big foil surround attaches to the actual crystal element right in the center, and they are connected with a big glob of wax. (usually black)
over years of use, abuse, and mouths full of refuse; this wax will become a bit brittle and work its way loose from the crystal element.
when this happens, the vibration caused by your voice coming into the mic does not get fully transferred to the crystal element, and will cause the mic to sound "tinny", or, "distorted", or have a really low output level.
so how do we bring the mic back to life?
simple.
just use a cigarette lighter, or something similar, and re-melt the wax.
it usually takes a few passes of the lighter over the wax to get it to melt a bit, and of course you dont want to damage the foil or the crystal itself, so dont go crazy.
thats it. if your crystal in the element is still good, then this should bring the mic back to life.
also, dont forget that these mics are very old, and the electrolytics in them dry out with age.
might be a good idea to replace the few that are in there with new ones.
good luck,
