Daiwa 901 meter issue
It's connected to the same power supply that powers my radio. The cord is absolutely good, no issues with it at all. There's power inside the meter all over the place, except for the light bulbs. And all I had to do was run the negative from the jack in the back of the meter down to the case. Problem solved
OK now that I have read it again......and again......I am thinking they left out a ground. I;m guessing the meter lights use a single power wire and simply connect to the chassis on the other side. Sounds like that jack should have been connected to chassis ground. Both + and - wires from the jack go to the circuit board I am guessing. Crap like this is hard to solve unless you have hands on then sometimes five minutes and a multimeter will solve it.
Reactions: BJ radionut
Yes, exactly, except, the lights used to work without any coax being connected. I didn't tear the meter apart to actually check the lighting grounding source. I just happened to notice that while changing a jumper one day, the lights went out. Screwing the new jumper in place returned the lights. I didn't think it was a good idea to use the antenna shield as a DC ground, so just decided to ground the case with a jumper. I'm still scratching my head over the whole thing.
Reactions: Captain Kilowatt
I did commercial electronic servicing for 22 years and things like this really get too me. LOL I get almost obsessed with trying to find out WHY. LOL
