That's a much-larger than average display. Finding a 2-digit display that's an exact match for the pin-hookup pattern is probably a long shot. If you end using a pair of single digits that are not an exact replacement you'll end up using a piece of perforated board to mount the new ones. Each wire will have to be correlated to the correct pin on each new digit. It's laborious, but doable. Pretty sure they are common-anode digits.
