Marconi,it is definitely not a transformer. It's a choke.
Homer I agree that looks like a choke
Although the pattern looks better on the second model, and the maximum radiation is one degree lower, I prefer the first one for it's greater gain, and the longer basket to vertical length ratio. It contains the out of phase currents better. If not for the deep null at useful elevations it would look finger lickin' good.
Here are some things to check out with these two Vortex Eznec models that are not very convincing for me.
I've already posted about Vortex using Real/High Accuracy for the Ground Type in my post #26. I don't understand this function technically, but it does have some special use in modeling related to the ground. Eznec doesn't produce an error message for no reason. I never use this function, so I don't see the message, but it does not stop the model from working so it is not a critical error, it is a warning and I try to stay away from warnings.
The Mark i shows 1 wire number for the radiator, 4 wires numbers for the radials, and the rest of the 39 wires are for the radial loop. No mast wires and no wires for the radial off-set brackets to be seen.
The Mark II has 3 wires that make up the radiator, 4 wires for the radials, and the rest of the 37 wires are for the radial loop. I see no mast wires and no wires for the radial off-set brackets again.
The segments for the radiator and the near parallel radials should also be close to having equal segment lengths. We can see both models show different segment lengths, maybe by a 2:1 difference if you look close at the little segment junction dots. You can see how this work in the model I posted of the Mark2. Check the details at the bottom of the antenna images for the radiator length and the radial length. This shows the segment lengths I used and they are as close as I can get them. A rule of modeling I always try and follow.
The absence of the mast does not make much difference for a model, but you won't see how bad the CMC might be either if it is not included.
Setting the radials with a direct connection to the radiator, with no stand-off brackets produces a geometry check error as you will see in the image of a Vector 4K model I used to demonstrate.this problem.
See the PDF file example I posted below showing the geometry check error message as a result of my removing the off-set brackets from the Vector 4K model, and if you check close you will see the bottom for this example looks very similar to the Vortex models. I had to leave out showing the currents...the error will not let the model scan, so in this case the error is critical.
Homer, do you recall ever having such a problem with one of your homebrew Vectors? I seem to recall we talked about it back in the days.
If you check the Eznec Control Center view for the either of these Vortex images you will see all of the 3 Eznec tuning function tools, Loads, Transformers, and L Networks are all indicating zero 0. This means the function is not being used. I put a black mark beside each item.
Below is a PDF file with my example of the Geometry error and I included the two Vortex images for the Q82 Mark I and Mark II in landscape view (sorry) so I can see more of the images.
