I think over the years I've learned that besides all the peak and tunes, echo, 1/4 ratio..etc… It all comes down to the "Voice Tone" and the person behind it.
How much power does a real amplifier put out? One KW? It seems like more power is always needed.![]()
Welcome Mad Dog! From what I have heard about the 203, the dead key has to be kept low to keep from burning the amp up. Having a high dead key also reduces your modulation. With a 50w key swinging to 100w that would give you 50% modulation. This means that your signal strength might be good to a distant radio, but the audio will be quiet or not as loud as it could be. With the dead key at 25w, you would have 100% modulation swinging to 100w. If you are talking to a distant station and the 25w dead key isn't enough, you might be able to turn the dead key up and it might help get you there. Or it might not.Hi guys, I just have to chime in here to explain my observations with my set up. First of all I am running a Galaxy DX 949 peaked and tuned into an RM Italy KL 203P then out through a pair of Wilson trucker 2000's with Wilson's co phased coax. I have messed (hours) of tuning and this is what I have arrived at: 3-4 watt deadkey from the radio gives me a 50 watt deadkey with the amp on. It does not swing alot on average power but will do 100 pep. Audio tests that I recorded seem very good, nice and clean with mic gain set at about 3 o'clock. I have tried less deadkey from the radio but this seems to show decent results on my MJF meter and the audio quality is clear and not overmodulated. To be honest I have pretty much accepted this as normal for my situation. Clean, loud and no distortion. Does this seem good? Thoughts?
