I never converted it to more that 14.5V but you could try: https://www.eevblog.com/forum/projects/hp-hstns-pd30-voltage-mod/
Thank you.I never converted it to more that 14.5V but you could try: https://www.eevblog.com/forum/projects/hp-hstns-pd30-voltage-mod/
Jeff, I think where a problem comes is that the dc side electrolytic caps in those supplies are only rated at 16 volts. You could probably up the values and experiment.Thank you.
I also messaged the seller for info but so far no answer to my questions.Jeff, I think where a problem comes is that the dc side electrolytic caps in those supplies are only rated at 16 volts. You could probably up the values and experiment.
