Two numbers to consider.
Voltage rating.
Current rating.
The 32-Volt fuse was better than nothing, but tends to blow more slowly than a fuse meant for 125 or 250 Volts. Either of those is appropriate, but the 32-Volt fuse is not a good idea, as a general rule. Either 125 or 250 is fine, but 32 Volts is a not-so-good second choice.
The current rating for five tubes would be closer to 10 Amps, max.
And that's why I suggested that the fuses may or may not have protected the transformer when they tripped. They were a bit large. The rating was small enough to protect your house from burning down, but a bit large to properly protect the transformer from harm.
Might have gotten away with it. Only one way to find out.
Voltage rating.
Current rating.
