Don't ever confuse that cable with hardline. It is as much hardline as my shoe lace. No disrespect meant BTW it's just that it is NOT hardline nor is it what most people mistakenly call hardline which is heliax cable. That BR400 simply has a solid centre conductor as a lot of coaxial cables have but that does not make it hardline.Real hardline is simply copper tubing both inside and out that uses special fittings to connect pieces and make bends. A lot of peoploe call heliax cable hardline too but it's not. Heliax cable has a corrugated outer sheath that allows it to bend some but it is still quite stiff and easy to kink and ruin. When dealing with 2m and especially 70cm you want the very best cable you can afford and if the specs on that Browning cable are true you are probably OK with it on 2m up to 50 feetbut 70cm is going to have extra losses. If you have good signals from repeaters in youir area you should be good however.For anything over 50 feet on 70cm I recommend
Andrew LDF4-50 as a good starting point. You don't need the LDF7-50 as King Cobra uses. He is just plain nuts and has more money than common sense.
LDF-7 is used in commercial FM broadcasting and cellular carriers with many kilowatts of power.
