Yes the grease was meant for the O-rings and Andrew was very explicit about not getting any on the center pin. 1/2 inch cable is not too hard to work with but the 1 5/8 and 3 inch stuff can benefit from a little grease to help the O-ring seat in place. Not many folks here are running that stuff however. LOL My comment about using it on only the threads comes from other manufacturers that state that it is acceptable and in some cases advisable to use it on the external male threads of the antenna connector to help prevent corrosion of the threads if moisture should get in and then make it impossible to remove the connector thus ruining the antenna.
