Differences between Uniden Grants and Older SS 3900 GHP
70cst
Well-Known Member
Dec 4, 2009
627
186
53
72
I am wanting to purchase an older Uniden Grant to hook up with my mid 80's Gray 300 amp once I get some extra change saved up. I saw a "gold" style 3900 that I might me able to pick up but if it's not that good of a radio then I will pass. Question...are these two radio similiar in recieve and transmit? Thanks in advance.
  • @ Geoexplorer69:
  • @ Geoexplorer69:
