Thanks, Tallman! That's what I was looking for. So John has the diodes set up on the negative side, not the positive side. I will get them all fixed up!
~Cheers~
~Cheers~
I think the supplies are well made. But switching supplies are like our next generation of phone pokers. A regulated supply will be stable and dependable(heavy), The switchers fight and power(amp) down to protect themselves.
exit,
just for funsies, have a look at this video of a similar power supply that Mike did:
LC
On an industry standard - ground 12V supply the load sensing is on the negative lead normally. If you look at master slave designed units this is what you see plus a jumper to set them as master or slave. Usually a system of resistors to supply a constant load is sufficient. I too thought a diode was a requirement but I learn something new everyday. I am a hobbyist not a professional!Well, I do know that the supplies are not happy running in parallel... they make a hissing sound and it makes the amp do some weird things, too. Any suggestions on what I can do to remedy that problem?
~Cheers~
