I've see seen what these do when they fail, and they often fail strangely. For instance, I recently had a problem with a Marantz amplifier, where it presented multiple different symptoms. It would start out playing fine, then it would start clipping more and more, until I was only getting the negative side of the waveform. If I turned the volume up, it would sound scratchy, as though there were a dirty potentiometer, even though the potentiometers are absolutely clean. The gradual nature of the clipping usually suggests a capacitor, since it would build up over time, and go away after allowed to rest, and it was even impervious to freeze spray on the transistors. I had replaced all the aluminium electrolytic capacitors though, so I then replaced the tantalum capacitors, with no effect. I removed the transistors and tested them with a transistor tester before I replaced capacitors, and all tested fine, but I decided to remove them once more, after replacing all the tantalum caps, and test them on a curve tracer, and two of them were bad.
They will appear good, and even test good with your average tester, and will present symptoms not normally associated with transistors, but actually be bad, and the only way to test them properly is with expensive equipment most people don't have, and given how cheap their replacements are, are more cost effective to replace than to test.
