Does swrs effect reception as well
Ok ty. Yeah no where have I even seen anything about the little antenna. Having in connected while doing the other test effect results?
Sent from my SCH-I535 using Tapatalk
Connect the FS antenna only when doing field strength testing. I've seen lots of these meters; some give false readings (or at least DIFFERENT readings) on power and SWR when the FS antenna is connected.
By the same token, don't touch the FS antenna port - that may throw your readings off too.
