doesn't make sense to me
handy andy what is the correct value for R 131 to get more out it that circuit i've seen people claiming to change it to 1.2 or 1.5 but never work me ??? other also say to go up on value ???
Well you really don't change R131, you change the LEVEL of signal it works with...
R131 and (See Graphic below inclusive R130) set a "gain" of the Mic limiter...so keep the 10K and the 1.5K where they are...
  • You may have a Diode to control the DIRECTION of power escaping the Base of TR26 while others are Pre-Set to ON Class A...R130 or VR12 (per model)
You change the OUTPUT of TR26 instead.
Locate R127 a 1M (Brown Black Blue) - change it's value to a lower, much lower value - like 1K or even 680 - 560 ohms...
The other side of TR26 looks at the AM Regulator - R166 and R165 - a simple divider - increase R166 to as high as 10K and REDUCE R165 to 1K - gives you a bigger window of drive for AMC...this affects the circuit you messed with earlier - R195 taps R166 and R165 - once you have R166 raised, and R165 lowered - you can leave the mess you were working with.
Giving away my secretes (AGAIN!)
Why keep R131? Well, you can remove it, but if you run an amp - you might want to keep the ability to limit the input swing so you don't blow up the amp - especially if you are segue-ing to using MOSFET's in the near future.
TR26 is on all the time, you tip the balance, scales or the waterfall effect - by changing the power available to flow across the Collector and Emitter - leave the Base alone, you can make the R131 and R130 (per graphic) equal - but that's not going to change much...The Diode forces AMC to work more towards Negative - the valve effect the Diode has, pertains to this.
Think of TR26 as a Common Base amplifier, then you can figure out the rest a lot easier by just fiddling, fixing the power flow thru TR26 by changing R127, R166 and R165 - leave the ALC alone to fend for itself...
i knew there was an update just could find the info 1000uf it is thanks shockwave i'm happy with the results i never got the same watts out of it when i tried the 29 transformers best was max 7 1/2 watts compare to this transformer almost 11 watts
The radio shack choke provided maximum performance.
Average reading meter, no doubt.
A whistle has a higher average audio power going into the mike than your voice. Makes the average modulated power of the radio seem higher.
A peak meter would reveal very little difference. And that's what they hear on the other end, is the peak audio power. An average-reading meter is all very good, but only shows you part of the picture.
A whistle is Useless for testing since Nobody I have ever spoken with whistles to communicate.Even if the power was 10 times as much on a whistle it's useless for actual communications.A Voice Peak is a Far Better choice for ny modulated signal since it's what is used for communicating.I hear people whistle to tune an amplifier & they get upset when the amp will not put out the same output when they talk.It's quiet Funny to me. :rolleyes::LOL::p
SIX-SHOOTER
From what you describe, your radio sounds like it has no "" swing kit "" in it.
Most radios, as you turn down the dead key, the peak will drop as well.
What is a Exit 13 tune?
And
I agree with Nomad:
And, as has already been said a bird on AVG is not the proper way to measure AM.
Many BIRD meters do have a PEP Reading Kit in them either from the factory or an aftermarket model so it's possible he has one of those but he did not say either way unless I missed it somewhere?
SIX-SHOOTER
Man, I need to pop in here and read the threads more often... Just been so busy.
Looks like someone tried to do my NPC/RC mod, with less than favorable results.
A few points to bring up...
This HAS to be done with an o'scope, a signal generator, and a spectrum analyzer. Not a power meter.
The AMC is not disabled, nor is it modified in my mod.
The AMC was not properly adjusted in this case.
It is not necessary to replace the C1419 with a TIP41C, but TIP41C's are cheap, and can run cooler.
R228 doesn't have to be changed, it can be left alone, but I've found that changing it to 1.5K yields a small improvement.
Changing or removing R131 is modifying the AMC circuit, and is a waste of time.
I'll get back to this when I have time.
~Cheers~
SIX-SHOOTER i have a separate pep meter and besides that not the problem
if you watch the video at that low power level when listening to the audio on another radio you can hear the audio falling off but never at a higher level
Put a PEP Kit in the BIRD.
SIX-SHOOTER
Reactions: W4KVW
hello exitthirteen if you read thru my remarks there is only one bug that it's only in the 1/2 to 1-watt range level yes the mod was done as you wrote it took it to a shop to be adjusted on a scope BUT keyword here it said set radio around 2 watts no problem
until when i run my 2 pills and the drive falls in the 1/2 watt or 1 watt and while talking local barefooted when i been told my audio is fading bring the dead key up and problem solve
~Cheers~
So it works ok without the amp?
What is the input SWR on the Amp?
What I am asking, if you put a SWR meter behind the radio and in front of the amp, turn amp on , key up, adjust set point, read SWR going into the amp.
Is it high?
