See, I thought that was the picture of the inside of an amp, not a stinger board...things didn't register at the time. Interesting, I will need to see if there is anyone around who can do that mod.
I'm thinking if I go with a stinger board, then I have two other radios I can use...one is a PC76 the other is a PC78W...so SSB would not be an issue. But I'm still concerned about RFI (since most new cars are susceptible)...I'd probably be able to under drive it in order to prevent RFI? See what I come up with...
My thoughts on doing a dual final mod to a 959 or installing a stinger board in ANYTHING.................
The KL203 and AD203 amps are class C, and will sound bad on SSB. If you plan to run SSB, I wouldn't recommend going with this setup. A local of mine bought two of them, thinking they'd work on SSB, so he installed one, and it sounded horrible.... and the neighbors complained. So he uninstalled it, and gave them both away. Ended up getting a Killer Bee 250HDV (T/S 250 HDV) and runs that instead. No complaints, and crystal clear on SSB.
The AD203 would be ok for AM use.
~Cheers~
Yeah, I just don't want to install an external amp...was trying to figure out if adding a second final to a radio I already own was better than buying a dual final radio. My biggest fear is this new truck will suffer from RFI if I go to big or if I have something that's not clean. I have three radio choices, the 959 is the only one that can have the dual final mod done.
I have a lead on a Stryker 447HPC for $175 locally, but I'm reading its a single "flange-mounted" transistor, which indicates its like a 2290/2879? Thinking it would be too much? Again, my fear is RFI in this new truck.
ExitThirteen, when I emailed RM Italy, they told me the 203P was A/B biased. I found it hard to believe, especially when they are available for 50 bucks at h and y. I am not as technically gifted as you, so you may "see" something different on the board than what they are saying. I have not played with mine much, but was running my Uniden Grant XL at stock power through the amp, and seeing about 100 watts out with the amp. I did not have time to get any radio checks to see how it sounded.
73,
RT307
Bored? Curious? Hobby? Why not?
On topic, I'd go with something external still, and not get the dual final mod done. 9C1Driver has a good point, the Galaxy radios are subpar, and really not worth putting extra money into. The Uniden PC76 and 78's are a far better radio if you're going to just run AM only.
The Stryker 447HPC has a 2SC2290 in it. As long as you don't remove the modulation limiter, and it has a proper peak & tune, you shouldn't have any trouble with the radio.
~Cheers~
Let's see.......a stock tuned 959 might swing 20 watts. A 959 with a dual final mod might swing to 35-40 watts peak. Do you think going through all that is worth it, I sure don't.
Stinger boards are notoriously problematic.
Absolutely worth it!
Looks to be an hour of work or less, and with the new regulator and audio driver suggested earler will do even more.
Who wouldn't want to kick their amp with 50W of PEP instead of 15?
And with just an hours work that will kick that amp for years to come?
Just install the 2 switch freq mod and save yourself buying a 99V. Oh yeah.
Seems a no brainer to me.
